Ana içeriğe geç
12-String Takamine G Series Guitar String Replacement
Neye ihtiyacın var
  1. 12-String Takamine G Series Guitar String Replacement, Guitar String: adım 1, 3 resimden 1. 12-String Takamine G Series Guitar String Replacement, Guitar String: adım 1, 3 resimden 2. 12-String Takamine G Series Guitar String Replacement, Guitar String: adım 1, 3 resimden 3.
    • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
    • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
    FixBot'a Sor
    Yorum Ekle
  2. 12-String Takamine G Series Guitar String Replacement: adım 2, 2 resimden 1. 12-String Takamine G Series Guitar String Replacement: adım 2, 2 resimden 2.
    • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
    FixBot'a Sor
    Yorum Ekle
  3. 12-String Takamine G Series Guitar String Replacement: adım 3, 2 resimden 1. 12-String Takamine G Series Guitar String Replacement: adım 3, 2 resimden 2.
    • Place the new string into the hole in the bridge where the pin was taken out.
    FixBot'a Sor
    Yorum Ekle
  4. 12-String Takamine G Series Guitar String Replacement: adım 4, 3 resimden 1. 12-String Takamine G Series Guitar String Replacement: adım 4, 3 resimden 2. 12-String Takamine G Series Guitar String Replacement: adım 4, 3 resimden 3.
    • Place the pin back into the hole to secure the string.
    FixBot'a Sor
    Yorum Ekle
  5. 12-String Takamine G Series Guitar String Replacement: adım 5, 1 resimden 1.
    • Grab the string and put it through the hole located on the tuning post of the guitar.
    FixBot'a Sor
    Yorum Ekle
  6. 12-String Takamine G Series Guitar String Replacement: adım 6, 3 resimden 1. 12-String Takamine G Series Guitar String Replacement: adım 6, 3 resimden 2. 12-String Takamine G Series Guitar String Replacement: adım 6, 3 resimden 3.
    • Take the string and wrap it around and underneath itself.
    • Pull the string taught.
    • Twist the string over itself and than cut off the excess string.
    FixBot'a Sor
    Yorum Ekle
  7. 12-String Takamine G Series Guitar String Replacement: adım 7, 2 resimden 1. 12-String Takamine G Series Guitar String Replacement: adım 7, 2 resimden 2.
    • Turn the tuning peg counterclockwise to tighten the string.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Rey Navarro
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 52
Her zaman: 855
