Ana içeriğe geç
1922 GE AOU Fan Power cord Replacement
Neye ihtiyacın var
  1. 1922 GE AOU Fan Power cord Replacement, Power cord: adım 1, 2 resimden 1. 1922 GE AOU Fan Power cord Replacement, Power cord: adım 1, 2 resimden 2.
    • Tip the fan to its side and remove the three size 8 screws using a 9/32 flat-head screwdriver.
    • The screws may be brittle from age, so be careful.
    • Take the bottom plate off the fan and set it aside.
  2. 1922 GE AOU Fan Power cord Replacement: adım 2, 1 resimden 1.
    • Remove the three number 8 screws that hold the switch in place.
  3. 1922 GE AOU Fan Power cord Replacement: adım 3, 1 resimden 1.
    • Remove the switch, carefully sliding the speed lever out of its slot.
    • Don't remove the switch too quickly or you can damage the head-wire.
  4. 1922 GE AOU Fan Power cord Replacement: adım 4, 1 resimden 1.
    • Once the switch is free, unscrew the two knurled nuts holding the wires in place.
  5. 1922 GE AOU Fan Power cord Replacement: adım 5, 1 resimden 1.
    • Turn the switch over and unscrew the nut securing the wire with the 5/16 crescent wrench.
  6. 1922 GE AOU Fan Power cord Replacement: adım 6, 1 resimden 1.
    • Remove the switch and set it aside, then pull the wire through the grommet.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elias Dorna
125 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 3-5, Rauch SU 2016 Texas Tech, Team 3-5, Rauch SU 2016 üyesi
TTU-RAUCH-SU16S3G5
2 Üyeler
1 Kılavuz yazıldı
1Rehber Yorum
Westinghouse table fan needs new cord (just bought). 18 gauge cord? Where to buy?
carol w - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 2,996
