Ana içeriğe geç
1980 Honda Prelude Headlight Replacement
Neye ihtiyacın var
  1. 1980 Honda Prelude Headlight Replacement, Headlight: adım 1, 3 resimden 1. 1980 Honda Prelude Headlight Replacement, Headlight: adım 1, 3 resimden 2. 1980 Honda Prelude Headlight Replacement, Headlight: adım 1, 3 resimden 3.
    • Turn off the car, pull the key out of the ignition, and turn off the cars lights.
  2. 1980 Honda Prelude Headlight Replacement: adım 2, 3 resimden 1. 1980 Honda Prelude Headlight Replacement: adım 2, 3 resimden 2. 1980 Honda Prelude Headlight Replacement: adım 2, 3 resimden 3.
    • Pull the hood latch underneath the steering wheel.
    • Open the hood, and place the hood prop in place to hold the hood upward.
  3. 1980 Honda Prelude Headlight Replacement: adım 3, 3 resimden 1. 1980 Honda Prelude Headlight Replacement: adım 3, 3 resimden 2. 1980 Honda Prelude Headlight Replacement: adım 3, 3 resimden 3.
    • Remove the socket from the headlamp by pulling gently.
  4. 1980 Honda Prelude Headlight Replacement: adım 4, 3 resimden 1. 1980 Honda Prelude Headlight Replacement: adım 4, 3 resimden 2. 1980 Honda Prelude Headlight Replacement: adım 4, 3 resimden 3.
    • Remove the screws holding the corner body trim with a Philips screwdriver.
    • Turn the screwdriver counterclockwise to loosen the screw.
  5. 1980 Honda Prelude Headlight Replacement: adım 5, 3 resimden 1. 1980 Honda Prelude Headlight Replacement: adım 5, 3 resimden 2. 1980 Honda Prelude Headlight Replacement: adım 5, 3 resimden 3.
    • Remove the corner body trim price, and unscrew the horizontal adjustment screw.
  6. 1980 Honda Prelude Headlight Replacement: adım 6, 3 resimden 1. 1980 Honda Prelude Headlight Replacement: adım 6, 3 resimden 2. 1980 Honda Prelude Headlight Replacement: adım 6, 3 resimden 3.
    • Remove the left horizontal adjustment screw by sticking the screwdriver through the hole.
  7. 1980 Honda Prelude Headlight Replacement: adım 7, 3 resimden 1. 1980 Honda Prelude Headlight Replacement: adım 7, 3 resimden 2. 1980 Honda Prelude Headlight Replacement: adım 7, 3 resimden 3.
    • Remove the bottom bracket screw.
  8. 1980 Honda Prelude Headlight Replacement: adım 8, 3 resimden 1. 1980 Honda Prelude Headlight Replacement: adım 8, 3 resimden 2. 1980 Honda Prelude Headlight Replacement: adım 8, 3 resimden 3.
    • Remove the top bracket screw.
  9. 1980 Honda Prelude Headlight Replacement: adım 9, 3 resimden 1. 1980 Honda Prelude Headlight Replacement: adım 9, 3 resimden 2. 1980 Honda Prelude Headlight Replacement: adım 9, 3 resimden 3.
    • Push the headlamp towards the front of the car.
    • Remove the bracket from the headlamp, and follow the steps to reassemble the headlamp.
    • Tilt the headlamp backward, and pull it towards you.
  10. 1980 Honda Prelude Headlight Replacement: adım 10, 3 resimden 1. 1980 Honda Prelude Headlight Replacement: adım 10, 3 resimden 2. 1980 Honda Prelude Headlight Replacement: adım 10, 3 resimden 3.
    • Check the replaced headlight is working by turning the light knob inside the car on.
    • If the lights do not turn on: the car might have an electrical issue. Contact your local mechanic for diagnosis.
Sonuç
In Conclusion, learning how to replace your headlight bulb for your 1980 Honda Prelude is important for your, and other driver's safety on the road.
Alexander Ortega
181 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 139
