Giriş
Use this guide to change the motor oil and filter on your E30.
Neye ihtiyacın var
Lift the car enough to place a jack stand underneath a flat portion of the frame rail just behind the control arm bushing.
Gently allow the car to fall onto the jackstand, lifting the car and re-adjusting its position as necessary.
Once all of the weight has been transferred to the jack stand, tighten the release plug on the jack and leave it positioned under the jack point as seen in the third picture.
Locate the oil pan drain plug. It will be located on the passenger side of the oil pan nearest the center of the car.
Locate the oil filter. It will be located beneath the exhaust manifolds.
Dip your finger into a bit of the oil you just drained from the engine and spread it on the large O-ring around the open end of your new oil filter.
Finger tighten the drain plug back into the oil pan.
Use your 17 mm wrench to tighten the drain plug.
Jack up the car slightly to remove the jack stand.
Remove the jack stand and carefully let the car slowly drop to the ground.
Remove the jack and set it aside.
Twist the oil filler cap 1/4 turn counter-clockwise and remove it from the valve cover.
Pack a clean paper towel below the oil filler hole on the valve cover to catch any oil that might spill.
Fill the engine up with 4.5 Quarts of oil. The M20 engine uses 20W-50 conventional oil.
After you've filled the oil, wipe up any spills with your towel.
Reinstall the oil filler cap.
Start the engine, and let it run for a minute or two to allow the oil to circulate through the filter.
I usually allow the car to sit for about 20 minutes, then check the oil once more. Add oil if necessary. Afterward, it is a good idea to drive for a bit (let the engine get up to operating temperature), then park it on a level surface and let it cool down for a couple hours before checking the oil level once more.
Clean up all your materials. Be sure to recycle your oil at an auto parts store such as AutoZone. Most landfills will have special days when you can take your used oil filter to be recycled.
23 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Boy, oil changes from the dealership sure have gotten expensive, and places like jiffy lube wont touch a BMW (probably a good thing). I usually have my boyfriend change the oil in our cars, but this guide is so complete....between the photos and the description, the instructions are so clear, that I think I am going to start changing the oil in my 1987 325i myself. He has a lot on his plate, so if I can take over some of the simple maintenance chores on my car, I think he would appreciate it. Thank you for this comprehensive guide.
if you are looking for promo on products then click
<a href="https://www.padspromo.com/">promo on products</a>
if you are looking for Oil change sticker then click
<a href="https://www.padspromo.com/:quicksearch.h...>Oil change sticker</a>
if you are looking for License plate frames then click
<a href="https://www.padspromo.com/:quicksearch.h...> License plate frames</a>
if you are looking for teardrop flags then click
<a href="https://www.padspromo.com/:quicksearch.h...>teardrop flags</a>
if you are looking for Custom Tents then click
<a href="https://www.padspromo.com/:quicksearch.h...>Custom Tents</a>
