Giriş
The idler arm is an essential part of the steering and suspension system on a truck. If the idler arm is not functioning correctly, then it will eventually completely break and leave the truck unable to be steered. This guide will take you through how to replace a bad arm.
Neye ihtiyacın var
First the truck should be prepared to be worked on.
Disconnect the negative battery terminal from the battery in order to be sure that no electrical current is running through the truck.
Set the parking break and put the truck in 1st gear.
Be sure to chock the wheels, so that it will not roll while you are underneath.
The first step is to remove the set nut holding the arm to the relay rod.
Begin with cleaning any oil and dirt from the set nut and then spray with the penetrating lubricant.
Once the spray has sat for 5 minutes, use needle nose pliers to straighten the cotter pin and pull it out.
Remove the set nut using a 19 mm socket.
Now that the relay rods are disconnected, the arm can be unbolted from the frame.
Spray both the bolts and the nuts with the penetrating lubricant.
On the bolt head use the breaker bar and 17 mm socket; put the 17 mm box wrench on the nut on the back side of the arm.
The wrench will get stuck on the frame and the breaker bar can then be used to break the rust off the bolt holding it onto the frame.
Once the bolt is loose a socket wrench can replace the breaker bar to make the job easier.
The (2) 4 1/4" bolts go on either side of the arm. The (1) 3 1/2" bolt goes at the top.
2 farklı kişi bu kılavuzu tamamladı.
