Ana içeriğe geç
1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance
Neye ihtiyacın var
  1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: adım 1, 2 resimden 1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: adım 1, 2 resimden 2.
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 2, 2 resimden 1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 2, 2 resimden 2.
    • Unlatch the two clasps, as outlined in the image.
    • Loosen the screw on the metal band, using a flathead screwdriver.
  3. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 3, 2 resimden 1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 3, 2 resimden 2.
    • Disconnect the electronic sensor from the MAF.
    • Press on the 2 latches, pulling the cable away from the sensor.
  4. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 4, 2 resimden 1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 4, 2 resimden 2.
    • Disconnect the rubber hose from the MAF.
    • Remove the MAF from the air filter housing.
  5. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 5, 1 resimden 1.
    • Steps 4-6 are for cleaning only.
    • Spray the MAF cleaner along the direction of travel, shown by the arrow on top of the sensor.
    • (Mass Air Flow sensor Cleaner)
  6. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 6, 2 resimden 1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 6, 2 resimden 2.
    • Clean the electronic coupling with an electronics cleaner.
  7. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 7, 2 resimden 1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 7, 2 resimden 2.
    • Inject conducting lubricant into the MAF sensor electronic coupling.
  8. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 8, 3 resimden 1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 8, 3 resimden 2. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 8, 3 resimden 3.
    • Reattach the MAF to the air filter housing and the intake hose.
    • Tighten the screw on the metal band.
    • Latch the clasps on either side of the MAF.
  9. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: adım 9, 1 resimden 1.
    • Reattach the electronic cable to the MAF.
Sonuç
Isaac Nitschke
67 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G28
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 9,735
