Ana içeriğe geç
1985-1988 Volvo 740 Tire Rotation
Neye ihtiyacın var
  1. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Front Wheels: adım 1, 1 resimden 1.
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  2. 1985-1988 Volvo 740 Tire Rotation: adım 2, 1 resimden 1.
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame of car.
    • Only necessary to jack the car until the wheels are just off the ground.
  3. 1985-1988 Volvo 740 Tire Rotation: adım 3, 1 resimden 1.
    • Place jack stand on frame of car and remove jack.
    • Do no work under car supported only by hydraulic jack, serious injury or death may occur.
  4. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Rear Wheels: adım 4, 1 resimden 1.
  5. 1985-1988 Volvo 740 Tire Rotation: adım 5, 2 resimden 1. 1985-1988 Volvo 740 Tire Rotation: adım 5, 2 resimden 2.
    • Place jack head underneath frame couple (pictured).
  6. 1985-1988 Volvo 740 Tire Rotation: adım 6, 2 resimden 1. 1985-1988 Volvo 740 Tire Rotation: adım 6, 2 resimden 2.
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
  7. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: adım 7, 2 resimden 1. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: adım 7, 2 resimden 2.
    • Pry off the all four hub caps by placing a small flathead screwdriver between hubcap and rim pulling the screwdriver away from tire.
    • Pull hubcaps away from tires.
  8. 1985-1988 Volvo 740 Tire Rotation: adım 8, 1 resimden 1.
    • Loosen each of the five lug nuts on all tires by turning them counter-clockwise with a 19mm wrench.
  9. 1985-1988 Volvo 740 Tire Rotation: adım 9, 1 resimden 1.
    • Remove tires by pulling directly away from car exposing brake rotors.
  10. 1985-1988 Volvo 740 Tire Rotation: adım 10, 1 resimden 1.
    • Swap tires according to diagram.
  11. 1985-1988 Volvo 740 Tire Rotation: adım 11, 1 resimden 1.
    • Place tires on axels.
    • Hand tighten the lug nuts with narrow end of nut towards car.
    • Finish tightening the lug nuts with 19mm Torque Wrench to a torque of 63 lb*ft.
Sonuç
Garrett Van Ruiten
54 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G28
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 2,636
