Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Brake pads are one of the most common causes of undesirable automotive noises. Often, annoying squeals and squeaks are dirty or worn brake pads. Stop making pedestrians cringe when you pull up to an intersection by installing some new brake pads.
Neye ihtiyacın var
Jack up the front of the car and place it on jack stands.
Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
Pull the front wheel off the wheel lugs and set it aside.
Insert the tip of a skinny screwdriver in the eyeholes of the clips and lift them off of the dowels.
To reassemble your device, follow these instructions in reverse order, starting at step 4.
3 farklı kişi bu kılavuzu tamamladı.
