Ana içeriğe geç
Giriş
There are multiple reasons to install wheel adapters on your Volvo 240. You may have spent a whole lot of money on racing wheels that ended up being the wrong size and now you can't return them. Perhaps there are some wheels you've had your eye on that are a different bolt pattern than the stock 5x108 Volvo wheels. Whatever your reason, wheel adapters will allow you to install wheels with a different bolt pattern than your factory wheels.
Wheel adapters, just like wheel spaces, place the wheel farther away from the stock hub location. This may cause excessive stress on your suspension if the adapters are too large. Also, very thick adapters may force you to roll the fenders of your car to keep the tires from rubbing against them.
Parçalar
Hiçbir parça belirtilmedi.
  1. Jack up the front of the car and place it on jack stands. Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death. Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. Place the wheel adapter over the existing wheel lugs, then install and hand-tighten the provided lug nuts. Tighten the lug nuts to 85 ft-lbs with a torque wrench or impact gun.
    • Place the wheel adapter over the existing wheel lugs, then install and hand-tighten the provided lug nuts.
    • Tighten the lug nuts to 85 ft-lbs with a torque wrench or impact gun.
    • The choice is yours as to what adapters you'd like to install. We chose 5x4.75 adapters so that we could equip our Volvo 240 with C4 Corvette wheels!
  3. Install your new wheels over the lugs of the wheel adapters and tighten the lug nuts to 85 ft-lbs.
    • Install your new wheels over the lugs of the wheel adapters and tighten the lug nuts to 85 ft-lbs.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
David Hodson
144.521 İtibar
127 adet Kılavuz yazıldı
2 Yorum
Can I ask what adapters you're running and what modifications did you make to the front for the salad shooters I'm doing the EXACT same adapting and we can't fit the 16x8.5 wheel on the front
will davis - Yanıt
What was the thickness of the spacers?
K P - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 7,755
