Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Jack up the front of the car and place it on jack stands.
Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
Pull the front wheel off the wheel lugs and set it aside.
Place the wheel adapter over the existing wheel lugs, then install and hand-tighten the provided lug nuts.
Tighten the lug nuts to 85 ft-lbs with a torque wrench or impact gun.
Install your new wheels over the lugs of the wheel adapters and tighten the lug nuts to 85 ft-lbs.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Can I ask what adapters you're running and what modifications did you make to the front for the salad shooters I'm doing the EXACT same adapting and we can't fit the 16x8.5 wheel on the front
