Ana içeriğe geç
1988-1994 Nissan Model 240SX Steering Wheel Replacement
Neye ihtiyacın var
  1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement, Steering Wheel: adım 1, 2 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement, Steering Wheel: adım 1, 2 resimden 2.
    • Gather the hardware, tools and protective equipment.
  2. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 2, 1 resimden 1.
    • Straighten the steering wheel and remove the key from the ignition.
  3. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 3, 3 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 3, 3 resimden 2. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 3, 3 resimden 3.
    • Grip the steering wheel horn pad, placing your fingertips at the edges.
    • Gently pull it straight towards you and the clips will release it.
  4. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 4, 1 resimden 1.
    • Use a paint marker to mark a reference point for the top center of the steering wheel on the face of the steering shaft.
  5. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 5, 2 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 5, 2 resimden 2.
    • Using a 19mm socket and ratchet, loosen the steering wheel retainer nut and remove it.
  6. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 6, 2 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 6, 2 resimden 2.
    • Place the puller tool on the wheel aligning the steering shaft with the press head and the two threaded holes in the steering wheel with the holes in the ears of the puller.
    • Run the bolts, from the puller tool, through the holes in the ears and thread them into the steering wheel hand tight.
  7. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 7, 1 resimden 1.
    • Slowly tighten the press shaft until the steering wheel releases.
    • This should not take much force to accomplish. If something starts bending or you have to use excessive force tightening the shaft, stop, reinstall the steering wheel retaining nut, and take the vehicle to a professional.
  8. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 8, 1 resimden 1.
    • Install the steering wheel hub onto the steering shaft, aligning the top center mark on the hub with the paint mark you made in Step 4.
  9. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 9, 2 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 9, 2 resimden 2.
    • Reinstall the steering wheel retaining nut torqueing it down to 29 ft*lb using a torque wrench.
  10. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 10, 3 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 10, 3 resimden 2. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 10, 3 resimden 3.
    • Place the inner horn retainer ring in-between the new steering wheel and hub, aligning the six bolt holes, and place one screw, finger tight, in the hub to temporarily hold everything in place.
  11. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 11, 3 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 11, 3 resimden 2. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 11, 3 resimden 3.
    • Make the wiring connections for the horn.
  12. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 12, 2 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 12, 2 resimden 2.
    • Press the horn into the inner horn retainer.
  13. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 13, 3 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 13, 3 resimden 2. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 13, 3 resimden 3.
    • Hold the assembly steady and remove the screw that was temporarily installed.
    • Place the outer horn retainer over the horn aligning the bolt pattern.
    • Reinsert the screw to temporarily hold the steering wheel assembly together.
  14. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 14, 2 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 14, 2 resimden 2.
    • Place a drop of low strength thread locking compound to each screw and thread them into the steering wheel hub.
    • Do not use excessive thread locking compound. It only takes a drop. This step is to ensure the screws do not loosen due to vibrations.
  15. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 15, 2 resimden 1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: adım 15, 2 resimden 2.
    • Tighten these screws using a 3 mm hex wrench.
    • Tighten the screws in a "star" pattern sequence starting with the bolt circled in red.
Sonuç
Bir başkası bu kılavuzu tamamladı.
GCV Engineering
141 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 68
Her zaman: 3,537
