Ana içeriğe geç
1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement
  1. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement, Pressure Regulator Fuel Return Line: adım 1, 2 resimden 1. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement, Pressure Regulator Fuel Return Line: adım 1, 2 resimden 2.
    • Pull the hood latch located underneath and left of the steering wheel until it unlatches. An audible "pop" will come from the hood when it has unlatched.
  2. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 2, 3 resimden 1. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 2, 3 resimden 2. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 2, 3 resimden 3.
    • Now that the internal latch is opened, a latch underneath the hood must also be unlatched. Put your fingers underneath the hood and lift up on the latch above and right of the Toyota emblem.
    • Remove the hooked end of the hood propping rod and allow it to pivot at the driver's side; place the hooked end in its receptacle to prop the hood.
  3. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 3, 2 resimden 1. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 3, 2 resimden 2.
    • Inspect the line for damage such as cracks, holes, and fuel seeps.
    • Continue the repair if it shows signs of these failures. Otherwise, the fuel leak is coming from elsewhere.
  4. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 4, 2 resimden 1. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #2 Screwdriver to loosen the hose clamps on the line until they move freely and are not constricting the hose.
    • Do not entirely unscrew the clamps, as they can be difficult to work with when fully unscrewed.
  5. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 5, 3 resimden 1. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 5, 3 resimden 2. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 5, 3 resimden 3.
    • Firmly grip the hose and pull one end outwards parallel from the main line. Repeat the process on the other end of the line.
  6. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 6, 2 resimden 1. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: adım 6, 2 resimden 2.
    • Remove the hose clamps from the damaged line. Straighten the used line out and place it alongside the new hose, then cut a piece the same length with the hose cutter (a sharp knife will also work fine).
    • Place the hose clamps on the new hose. There is no need to replace the old hose clamps.
Sonuç
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 136
Her zaman: 1,887
