Ana içeriğe geç
1990-1993 Honda Accord EX Engine Air Filter Replacement
Neye ihtiyacın var
  1. 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: adım 1, 3 resimden 1. 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: adım 1, 3 resimden 2. 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: adım 1, 3 resimden 3.
    • Flip the switch underneath the steering wheel to open the hood.
  2. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 2, 3 resimden 1. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 2, 3 resimden 2. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 2, 3 resimden 3.
    • Open the hood, and keep it in place using the prop rod.
  3. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 3, 2 resimden 1. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 3, 2 resimden 2.
    • Remove the four 1.3 cm Phillips screws from the cover of the case.
  4. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 4, 2 resimden 1. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 4, 2 resimden 2.
    • Remove the cover of the casing.
  5. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 5, 3 resimden 1. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 5, 3 resimden 2. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 5, 3 resimden 3.
    • Remove the old air filter and replace it with a brand-new one.
    • Place the new air filter in the same position as the old one otherwise, you will not be able to screw the cover back on.
  6. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 6, 2 resimden 1. 1990-1993 Honda Accord EX Engine Air Filter Replacement: adım 6, 2 resimden 2.
    • Place the cover back on the casing and screw it back in place.
    • Do not tighten the screws too hard or you risk the chance of breaking the screws.
Sonuç
Oscar Sanchez
133 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 102
