Ana içeriğe geç
1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement
Neye ihtiyacın var
  1. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement, Manual Driver’s Side Mirror: adım 1, 3 resimden 1. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement, Manual Driver’s Side Mirror: adım 1, 3 resimden 2. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement, Manual Driver’s Side Mirror: adım 1, 3 resimden 3.
    • Unscrew the two T25 Screws located on the sides of the mirror.
    • The mirror should be bolted inside (which we will get to later), so the mirror should not fall.
  2. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 2, 3 resimden 1. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 2, 3 resimden 2. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 2, 3 resimden 3.
    • Inside the door panel, there are two Philips screws. One in the panel's upper right side, the other inside the door pull. Remove both.
  3. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 3, 3 resimden 1. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 3, 3 resimden 2. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 3, 3 resimden 3.
    • Turn the crank handle until the knob is facing upward. Using a hook pick or a small flathead screwdriver, gently pry open the front cover.
    • Rotating the cover out of your way, unscrew the T20 screw from inside the handle.
    • To avoid losing the screw, slide the cover back over the handle without fully removing it. However, make sure not to clamp it closed.
  4. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 4, 3 resimden 1. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 4, 3 resimden 2. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 4, 3 resimden 3.
    • Three plastic retaining clips are located at the bottom of the panel. To remove those clips, either use a fastener removal tool or your hands.
    • Release the door panel from the door lock by lifting it up. To clear the door handle, move the door panel to the right.
  5. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 5, 2 resimden 1. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 5, 2 resimden 2.
    • With the panel removed. Locate the 10 mm bolt near the speaker at the top. Using a 10 mm socket, loosen the bolt.
    • Keep one hand on the mirror to prevent it from falling. This will remove the mirror from the truck.
  6. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 6, 2 resimden 1. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: adım 6, 2 resimden 2.
    • To remove the mirror, lift up and to the left to clear the arm inside the door.
Sonuç
Rachelcall
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 141
