Ana içeriğe geç
1993-1997 Toyota Corolla Headlight Bulb Replacement
  1. 1993-1997 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: adım 1, 1 resimden 1.
    • Reach underneath the panel below the steering column and pull the black lever to unlock hood. The lever will have an icon of a car with a propped open hood.
  2. 1993-1997 Toyota Corolla Headlight Bulb Replacement: adım 2, 1 resimden 1.
    • Place two fingers underneath hood but directly on top of Toyota emblem to locate hood latch. Push up with both fingers to unlock latch.
  3. 1993-1997 Toyota Corolla Headlight Bulb Replacement: adım 3, 1 resimden 1.
    • Located right behind the headlight is a red Deutsch connector. Push down on that connector to unplug wiring and rotate unconnected portion counterclockwise, facing from the driver's view, to remove bulb.
  4. 1993-1997 Toyota Corolla Headlight Bulb Replacement: adım 4, 1 resimden 1.
    • With bulb exposed, twist broken bulb counterclockwise to unscrew from electrical connection. Screw in new bulb clockwise and replace back into socket.
  5. 1993-1997 Toyota Corolla Headlight Bulb Replacement: adım 5, 1 resimden 1.
    • Be very careful twisting new bulb into electrical connection as the bulbs are very easily damaged.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Shane Moore
272 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-23, Donnelly Fall 2014 USF Tampa, Team 1-23, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G23
1 Üye
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 10,790
