Giriş
Replacement for an 1994 Jeep Cherokee XJ ECM. The ECM is something that can stop the engine from engaging and can become fried when working on electrical work. These older vehicles have frayed wires which can become exposed and cause a short circuit resulting in the need to replace your ECM. In order to get this replacement ECM you will need to reach out to local auto parts shops and provide the Make/Model and 2 or 4 wheel drive and Manual vs Automatic Transmission so they can help locate a replacement that fixes your vehicle. This is a step by step process, that shows how to remove the old ECM and install the new ECM.
Neye ihtiyacın var
Remove the air filter in the first picture to have access to your ECM.
The air filter can be disconnected from the throttle body. The second picture shows where to loosen the gasket connected to the throttle body.
The third picture shows an 8mm socket being used to loosen the gasket connected to the throttle body. Remove the air filter connection and place in a safe spot.
Bir başkası bu kılavuzu tamamladı.
