Ana içeriğe geç
1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement, 3.4L Timing Belt/ Water Pump: adım 1, 1 resimden 1.
  2. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 2, 1 resimden 1.
  3. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 3, 1 resimden 1.
  4. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 4, 3 resimden 1. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 4, 3 resimden 2. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 4, 3 resimden 3.
  5. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 5, 1 resimden 1.
    • Loosen up the idler pulley by getting underneath the car and removing the 12mm bolt at the bottom of the idler pulley .
  6. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 6, 1 resimden 1.
  7. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 7, 1 resimden 1.
  8. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 8, 1 resimden 1.
  9. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 9, 1 resimden 1.
  10. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 10, 1 resimden 1.
    • Remove the nut that holds the pulley in place, which should be torqued down to 250 lbs .
  11. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 11, 1 resimden 1.
    • Using a 19mm wrench and a pipe, remove the nut and then remove the pulley .
  12. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 12, 1 resimden 1.
  13. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 13, 1 resimden 1.
  14. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 14, 1 resimden 1.
  15. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 15, 1 resimden 1.
  16. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 16, 1 resimden 1.
    • Line up the notches on the camshafts to set the timing before removing the belt .
  17. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 17, 1 resimden 1.
  18. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 18, 1 resimden 1.
    • Line up the camshafts by rotating the big pulley until the notches line up .
  19. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 19, 1 resimden 1.
  20. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 20, 1 resimden 1.
  21. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: adım 21, 1 resimden 1.
Sonuç
Additional Information
- When lining up the camshafts, make sure to align the notches with the backplate, as well as the small arrow and dot on the bottom
- It is important to get all the old gasket off to prevent leaks.
4 farklı kişi bu kılavuzu tamamladı.
eCuration
376.693 İtibar
234 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.198 adet Kılavuz yazıldı
Bir Yorum
Thank you so much for the video! As for ordering the parts for this repair i will go ahead and save a lot of trouble for those of you who may not already know when asked about weather you need the water pump that comes WITH ot WITHOUT the ENGINE oil cooler stem, I own a 1999 Toyota Tacoma Four-Wheel Drive V6 3.4L 5-Speed Manual Transmission
NikkiAutumn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 118
Son 30 gün: 441
Her zaman: 61,200
