Giriş
Change the oil in your '95-'01 Honda CRV to improve engine performance and longevity.
It is typically recommended that you change your vehicle's oil every 3,000 miles. However, this number can vary depending on your operating conditions, age of your vehicle, number of miles on your engine and your driving habits. Use of synthetic oils can help reduce engine wear and are advisable for older engines or if your typical driving involves extended periods of stop and go traffic.
Neye ihtiyacın var
Begin by locating the lifting and stand points.
The lifting point is at the front and center of the car, just below the bumper.
The stand point is below the rocker panel on the driver's side of the car, just behind the front wheel
Locate the 17 mm hex oil drain plug. It is on the driver's side of the car facing backwards.
Place the oil drain pan under the oil drain plug.
Locate the oil filter. It is on the back side of the engine, near the engine's center line and adjacent to the rear engine brace.
Move the oil drain pan so it will catch any oil that spills when you remove the oil filter.
To reach the oil filter, guide your hand around the back side of the drive axle and up toward the top of the engine.
Twist the oil filter counter-clockwise with your hand until it comes off the threads on the engine block.
Lower the oil filter out of the engine bay with the threads facing up, then place it in the oil drain pan with the threads facing down.
Wipe off as much spilled oil as possible.
Guide the new filter back up and around the drive shaft, being careful not to get dirt or debris on the seal of the oil filter.
Place the threaded end of the oil filter onto the engine's oil filter threads and turn the filter clockwise by hand until it is snug. Tightening the filter should require a moderate amount of your strength, but not all of it.
Remove the oil drain pan from under the car.
Locate the hood release lever. It is below the left side of the driver console, just under the trunk release lever.
Pull the lever until you hear the hood click.
Go to the front of the car and locate the hood release latch. It is under the hood and slightly towards the passenger side of the car.
Lift up on the hood release latch and lift the hood open.
Place the end of the hood prop rod into the hole on the driver side of the hood marked by an arrow.
Locate the oil dipstick. It is at the front of the engine along its center line.
Pull out the oil dipstick, wipe it off, place it all the way back into its hole and remove again.
Observe the oil level on the end of the dipstick. It should be between the two holes or slightly above the top one.
Add oil if the oil level is below the bottom hole of the dipstick. Place the oil dipstick all the way back in it's hole.
I usually ensure mine is exactly on the upper mark.
Recently, the mechanic put excess oil so it went way above the upper mark, so I decided to lower it by pulling some out through a pipe attached to a syringe, because the pipe kept bending, I fastened it to a straw using a masking tape, the drain was going on well until the tape at the tip slipped and remained inside the sump /oil pan.
Is there need to worry or the oil pickup screen will prevent it from doing any damage until my next oil change?
Thanks.
Support the hood with one hand and use your other hand to place the hood prop rod back into its holder.
Gently lower the hood until it clicks into the secondary latch.
Press firmly on the edge of the hood until you hear the primary latch engage.
Start the car and look for leaks under the car. If there are leaks, shut the car off and determine if the drain plug or filter need to be tightened, or if a part has been damaged.
After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
Allow 12-24 hours for all the oil to drain out of your old oil filter.
Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
30 farklı kişi bu kılavuzu tamamladı.
13 Yorum
The filter is easier and not as messy to replace if you replace it from above. This also keeps debris from getting on the filter gasket.
There is even a small hole in the intake manifold so you can see what the filter threads onto.
if the engine reducing oil whats the cause is there any problem, kindly guide me
Check crank shaft seal (front/rear) and Head cylinder seal areas. Apart from that visit the dealership. Something as minor as an oil pressure sensor could also do that. Again your best bet is to go to a trust worthy auto shop by reviews or a well established and rated dealership. Any place else you'll increase your chances to be cheated.
Remove, and install a new filter, along with a clean gasket plug.
Mate, what do we use in Japanese Variant of Honda CR-V 2.0 Sport k20a4 engine type? Which grade engine oil? I've been using 5W30 Idemitsu API SM grade. I'm thinking to go down to 0W20 API SN, ILSAC GF-5 fully synthetic Idemitsu for this VTEC. Would adding stp fuel line and injector cleaner along with regular flush and engine synthetic base STP additives do harm?
Replacing it from above? Not on my 97 CR-V Unless you have very skinny arms with 2 double jointed elbows.
This was very educating on my part
This oil filter indeed is the hardest one i had . i thought Japanese liked to make things easier. My Toyota was much easier
Synthetic, semi-synthetic or mineral oil?
Synthetic is best, keeps your engine cleaner and has a longer change interval.
I've been using shell helix ultra 5w40 but decided to try out bizol 5w30 allround Hc-Synthese to see how it improves fuel economy.
That's after using bizol oil system clean plus o90 to clean and restore the engine's compression, works great for me.
Dun -
Thanks.
