Ana içeriğe geç
1995 Toyota Corolla Key Fob Motherboard Replacement
Neye ihtiyacın var
  1. 1995 Toyota Corolla Key Fob Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the single screw securing the key fob shell.
  2. 1995 Toyota Corolla Key Fob Motherboard Replacement: adım 2, 1 resimden 1.
    • After removing the screw, remove the back cap of the key shell with a flathead screwdriver and twist the screwdriver sideways.
    • Do not lever it upwards to prevent damage to the inner board.
  3. 1995 Toyota Corolla Key Fob Motherboard Replacement: adım 3, 1 resimden 1.
    • Carefully remove the motherboard inside the now open key without touching any of the inner metal components to prevent damage to the system.
  4. 1995 Toyota Corolla Key Fob Motherboard Replacement: adım 4, 1 resimden 1.
    • Once you have removed the board, repeat steps 1-2 with the new key and place the motherboard on the rubber.
  5. 1995 Toyota Corolla Key Fob Motherboard Replacement: adım 5, 1 resimden 1.
    • Place the cap back on the new key and screw everything back into place. Test the key on your vehicle to make sure that all the buttons work.
Sonuç
While this guide shows how to switch the board between shells, unless the key has a removable blade, you will need to get the new one cut with specialized equipment.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 430
