Ana içeriğe geç
1996-1998 Subaru Legacy Wheel Bearings Replacement
Neye ihtiyacın var
Video talimatları
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tim Asp
3.905 İtibar
8 adet Kılavuz yazıldı
4 Yorum
Excellent video on how to replace a Subaru Legacy Wheel bearing. I wish this video had been around when I replaced the both front wheel bearings on my 1997 Legacy GT. Although I did not have a micrometer my repair was still successful. I wanted to add in that a small Dremel tool would have been a great idea at the time of my repair and I highly suggest it for a job like this.
nshourds - Yanıt
Hello, I recently bought a 97 Subaru legacy outback, & it won't start. Guy I bought it from said he loaned it & the person put too much oil, then drove it about 5 miles it died & won't start still. Have checked all fuses, ran a diagnostic which read 02 sencers, & ignition something. Have any pointers for me. The guy I got it from also said b4 all this it ran great
Deseri - Yanıt
Does it turn over? Does it start then stop? What kind of noises does it make?
Tim Asp -
Try ground cables oil wouldnt have nothing to do with it starting. My 96 legacy outback had a similar problem took off ground cleaned and sanded dwn the holes and fired right up it even sounds like its gets more power. Check wired battery to starter. Battery to ground. Hope that helps good luck.
Jose Robles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 33
Her zaman: 11,018
