Ana içeriğe geç
1997-2006 Jeep Wrangler (TJ) Headlight Replacement
Neye ihtiyacın var
  1. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement, Headlight: adım 1, 1 resimden 1.
    • Unclasp and prop up the hood.
  2. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 2, 1 resimden 1.
    • Remove the three 15.9 mm screws around the external ring casing with a Phillips #0 screwdriver.
  3. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 3, 1 resimden 1.
    • Pull out the external ring casing.
  4. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 4, 2 resimden 1. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 4, 2 resimden 2.
    • Remove the four screws securing the internal ring casing with a T15 Torx screwdriver.
  5. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 5, 1 resimden 1.
    • Disconnect the headlight assembly from the vehicle by pulling the connector directly out of the back port.
  6. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 6, 1 resimden 1.
    • Realign the internal bracket to match the screw holes.
  7. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 7, 1 resimden 1.
    • Reinstall the four screws securing the internal ring casing with a T15 Torx screwdriver.
  8. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 8, 1 resimden 1.
    • Realign the external bracket to match the screw holes.
  9. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 9, 1 resimden 1.
    • Replace the three 15.9 mm screws using a Phillips #0 screwdriver.
  10. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: adım 10, 1 resimden 1.
    • Close and clasp the hood back to its original position.
Sonuç
Enjoy your bright new headlight(s)!
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 74
Her zaman: 3,444
