Ana içeriğe geç
1997-2004 Ford F-150 Air Filter Replacement
Neye ihtiyacın var
  1. 1997-2004 Ford F-150 Air Filter Replacement, Air FIlter: adım 1, 3 resimden 1. 1997-2004 Ford F-150 Air Filter Replacement, Air FIlter: adım 1, 3 resimden 2. 1997-2004 Ford F-150 Air Filter Replacement, Air FIlter: adım 1, 3 resimden 3.
    • Pull on the hood release handle located on the driver's side to the left of the brake pedal to pop the hood.
    • To open the hood, reach into the gap at the front of the truck and feel for the latch.
    • Push it to the left to release it and lift up on the hood.
  2. 1997-2004 Ford F-150 Air Filter Replacement: adım 2, 3 resimden 1. 1997-2004 Ford F-150 Air Filter Replacement: adım 2, 3 resimden 2. 1997-2004 Ford F-150 Air Filter Replacement: adım 2, 3 resimden 3.
    • The air filter box is located in the front right front corner of the engine bay.
    • To disconnect the Mass Airflow Sensor squeeze the tab on the connector and pull it away from the sensor.
  3. 1997-2004 Ford F-150 Air Filter Replacement: adım 3, 3 resimden 1. 1997-2004 Ford F-150 Air Filter Replacement: adım 3, 3 resimden 2. 1997-2004 Ford F-150 Air Filter Replacement: adım 3, 3 resimden 3.
    • Use a flathead screwdriver or a nut driver to loosen the hose clamp that attaches the air filter box to the air inlet tube.
    • When the clamp is loosened set the air inlet tube to the side.
  4. 1997-2004 Ford F-150 Air Filter Replacement: adım 4, 3 resimden 1. 1997-2004 Ford F-150 Air Filter Replacement: adım 4, 3 resimden 2. 1997-2004 Ford F-150 Air Filter Replacement: adım 4, 3 resimden 3.
    • Disconnect the air filter box clamp by pulling the clamp handle towards you.
    • This will loosen the clamp and allow the air box to separate.
  5. 1997-2004 Ford F-150 Air Filter Replacement: adım 5, 2 resimden 1. 1997-2004 Ford F-150 Air Filter Replacement: adım 5, 2 resimden 2.
    • To separate air filter box rotate it while pulling the left side of box upwards, removing it from the housing.
    • Once the left side of box is removed reach into the right side of the box and remove the air filter.
    • Dispose of the old air filter and replace with it with the new air filter.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 61
Her zaman: 824
