Ana içeriğe geç
1997-2003 Chevrolet Malibu Air Filter Replacement
Neye ihtiyacın var
  1. 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: adım 1, 2 resimden 1. 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: adım 1, 2 resimden 2.
    • The air filter housing is located on the driver side of the car.
    • Loosen the four housing screws on the plastic air intake box.
    • Do not try to remove these screws from the intake box, as they are not designed to be removed.
  2. 1997-2003 Chevrolet Malibu Air Filter Replacement: adım 2, 2 resimden 1. 1997-2003 Chevrolet Malibu Air Filter Replacement: adım 2, 2 resimden 2.
    • Loosen the hose-clamp on the air intake tube located on the side of the air intake box.
    • Remove the air intake tube from the intake box.
  3. 1997-2003 Chevrolet Malibu Air Filter Replacement: adım 3, 1 resimden 1.
    • Gently lift the top off of the air intake box.
  4. 1997-2003 Chevrolet Malibu Air Filter Replacement: adım 4, 1 resimden 1.
    • Remove the air filter from the housing and inspect it.
    • If it can not be cleaned, then it should be replaced with a new one.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sank Yang
484 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-15, Amido Fall 2012 Cal Poly, Team 9-15, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G15
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 5,490
