Giriş
Replacing the spark plugs in your Malibu can keep it running strong. New spark plugs will produce a stronger spark than older spark plugs allowing your engine to run smoother and more efficient.
Neye ihtiyacın var
Use the 1/2" socket to loosen and remove the four bolts and washers on the spark plug cover labeled 2.4L Twin Cam.
To reassemble your device, follow Steps 1-3 in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
