Ana içeriğe geç
1997-2003 Chevrolet Malibu Tail Lights Replacement
Neye ihtiyacın var
  1. 1997-2003 Chevrolet Malibu Tail Lights Replacement, Tail Lights: adım 1, 1 resimden 1.
    • Locate the plastic casing that holds the trunk liner in place, directly behind the tail light.
    • Unscrew the plastic casings.
  2. 1997-2003 Chevrolet Malibu Tail Lights Replacement: adım 2, 1 resimden 1.
    • Make sure to put some pressure on the tail light itself so it does not fall out when you unscrew it.
    • Unscrew the three plastic wing nuts located behind the tail lights.
  3. 1997-2003 Chevrolet Malibu Tail Lights Replacement: adım 3, 1 resimden 1.
    • When the tail light assembly comes loose, do not fully remove it because it may damage the connected wires.
    • Carefully pull the tail light away from the car to expose the connected wires.
  4. 1997-2003 Chevrolet Malibu Tail Lights Replacement: adım 4, 3 resimden 1. 1997-2003 Chevrolet Malibu Tail Lights Replacement: adım 4, 3 resimden 2. 1997-2003 Chevrolet Malibu Tail Lights Replacement: adım 4, 3 resimden 3.
    • Unclip the rear panel of the tail light assembly. There are two clips on the top and two on the bottom.
    • Remove the rear panel from the rest of the assembly.
  5. 1997-2003 Chevrolet Malibu Tail Lights Replacement: adım 5, 1 resimden 1.
    • Do not pull on the bulb, handle it gently because it is fragile.
    • Grab the plastic base of the bulb and gently wiggle it free.
  6. 1997-2003 Chevrolet Malibu Tail Lights Replacement: adım 6, 1 resimden 1.
    • When handling the new bulbs, avoid touching the glass as much as possible because this can reduce the life of the bulb.
    • Gently push the new bulb into the plastic housing.
  7. 1997-2003 Chevrolet Malibu Tail Lights Replacement: adım 7, 1 resimden 1.
    • After putting the new bulbs in, turn the desired lights on to check that the newly installed bulbs work correctly.
    • These bulbs have different functions including blinkers, brake lights, hazard lights, and back-up lights. They will only turn on when the necessary signal is sent.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sank Yang
484 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-15, Amido Fall 2012 Cal Poly, Team 9-15, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G15
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 19,379
