Giriş
Replacing burnt out or broken bulbs is a quick and easy fix that makes your car easier to see from behind, helping to prevent accidents.
Neye ihtiyacın var
Locate the plastic casing that holds the trunk liner in place, directly behind the tail light.
Unscrew the plastic casings.
Gently push the new bulb into the plastic housing.
98 Malibu Chevy left back bulbs replaced due to water in bulb sockets! Only turn signal works presently. Small Fuses aren't broken
Or showing burnt place. Can problem be the under hood fuse box, maxi or mini fuses? Please help.
Good question. What's the answer. I looked for a fuse and didn't see one
ro c -
What is the pattern for the bulbs in the tailight assembly
After putting the new bulbs in, turn the desired lights on to check that the newly installed bulbs work correctly.
My reverse lights work my turning signal works and my brake lights work but what's up with my dimmer lights you know when you're driving at night you have the dimmer lights and then you press the brake lights and the brake lights come on
What's the answer
ro c -
What bulbs do I need to use in the tailight assembly and which bulb goes where
4 farklı kişi bu kılavuzu tamamladı.
