Ana içeriğe geç
1997 Toyota Camry Stop and Tail Light Bulbs Replacement
Neye ihtiyacın var
  1. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: adım 1, 3 resimden 1. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: adım 1, 3 resimden 2. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: adım 1, 3 resimden 3.
    • Open the trunk.
    • Loosen three 15 mm screws using a Phillips #1 screwdriver.
    • Pull the cover clips at the base to remove.
    • Potential for device damage: Do not pull the cover clips prior to unscrewing as the cover clips can break.
    • Remove the cover by folding the cover backwards to expose the bulb assembly.
  2. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: adım 2, 2 resimden 1. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: adım 2, 2 resimden 2.
    • Grab the inner light bulb assembly using your thumb and forefinger.
    • Rotate the bulb assembly a quarter turn counterclockwise.
    • Pull it straight outwards until the bulb is displayed.
  3. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: adım 3, 1 resimden 1.
    • While holding the assembly, grab the base of the light bulb with your thumb and forefinger.
    • Pull the bulb away from the assembly until it detaches. Discard the old bulb.
  4. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: adım 4, 1 resimden 1.
    • Grab the new inner tail light bulb 3157 and push it into the bulb assembly.
    • Insert the bulb assembly straight into the socket. Rotate it a quarter turn clockwise to secure it.
  5. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: adım 5, 1 resimden 1.
    • Repeat this process with the outer light bulb assembly using bulb 904.
  6. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: adım 6, 2 resimden 1. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: adım 6, 2 resimden 2.
    • Unfold the cover and place it back over the bulb sockets. Push the three cover clips into their sockets .
    • Screw the three 15 mm screws in with Phillips #1 screwdriver to secure the cover.
Sonuç
Your stop and tail lights have been properly replaced and your replace bulb indicator should be off on your dashboard.
Ivan Navas
138 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 54
Her zaman: 2,240
