Ana içeriğe geç
1998-2012 Renault Clio II Battery Replacement
Neye ihtiyacın var
  1. 1998-2012 Renault Clio II Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Stop the car engine.
    • Indentify the car battery.
  2. 1998-2012 Renault Clio II Battery Replacement: adım 2, 1 resimden 1.
    • Identify the screw on the right side of the battery which maintains the battery.
  3. 1998-2012 Renault Clio II Battery Replacement: adım 3, 1 resimden 1.
    • WIth the 8mm box end wrench, remove the black (ground) cable.
  4. 1998-2012 Renault Clio II Battery Replacement: adım 4, 1 resimden 1.
    • WIth the 13mm wrench, remove the red cable.
  5. 1998-2012 Renault Clio II Battery Replacement: adım 5, 1 resimden 1.
    • Unscrew the bottom screw identify in step 2 with the 13mm socket wrench.
    • Remove the old battery.
  6. 1998-2012 Renault Clio II Battery Replacement: adım 6, 1 resimden 1.
    • Insert your new battery and lock the it with the screw.
    • Grease the battery contacts.
  7. 1998-2012 Renault Clio II Battery Replacement: adım 7, 1 resimden 1.
    • Put back the red cable and then the black one.
    • Start your car.
Bitiş Çizgisi
20 farklı kişi bu kılavuzu tamamladı.
sissssou
1.389 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 109
Son 30 gün: 525
Her zaman: 56,476
