Ana içeriğe geç
1998-2002 Honda Accord Distributor Cap Replacement
Neye ihtiyacın var
  1. 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: adım 1, 3 resimden 1. 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: adım 1, 3 resimden 2. 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: adım 1, 3 resimden 3.
    • Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
    • The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
    • Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
    There is a problem with the order, the first cylinder is on the right not on the left, always next to the timing pulley, the numbering is opposite.
    But following your reflection it is and all the same good
    Denis bache - Yanıt
  2. 1998-2002 Honda Accord Distributor Cap Replacement: adım 2, 1 resimden 1.
    • Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • It may be helpful to slightly twist the wires as you pull them.
  3. 1998-2002 Honda Accord Distributor Cap Replacement: adım 3, 2 resimden 1. 1998-2002 Honda Accord Distributor Cap Replacement: adım 3, 2 resimden 2.
    • Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
    • The position of the third bolt is not visible in the second picture.
  4. 1998-2002 Honda Accord Distributor Cap Replacement: adım 4, 1 resimden 1.
    • Pull the distributor cap away from the engine and set it aside.
  5. 1998-2002 Honda Accord Distributor Cap Replacement: adım 5, 2 resimden 1. 1998-2002 Honda Accord Distributor Cap Replacement: adım 5, 2 resimden 2.
    • Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
    • Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
4 Yorum
I need to do this procedure. Have never done this in years. Next time I will change my wires, plugs and now my distributor cap.
Thurman - Yanıt
Where can I find the part number?
lawendellr - Yanıt
what about 6 cylinder
ssingam75 - Yanıt
excellent, thanks for you aportation.
julio cesar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 38
Son 30 gün: 124
Her zaman: 68,318
