Giriş
Use this guide to replace a head light in your '98-'02 Honda Accord.
Pull on the hood release lever just inside the driver-side door to pop the hood.
Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
Insert the hood prop rod into the hole in the hood marked with an arrow.
Turn the head light bulb counterclockwise and pull it straight back to remove it.
27 farklı kişi bu kılavuzu tamamladı.
14 Yorum
I change both bulbs and still high beam don't work what else can be wrong
Nobody can replace the headlight for my 1999 Honda Accord (low beam). Everyone says the 9006 is supposed to fit the socket. The socket is fine; the connector for the new bulb is covered by a plastic sheath, which the old bulb doesn't have. Should I go to a dealer for this part?
Did you end up with a solution I'm having a similar issue
