Ana içeriğe geç
1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation
Neye ihtiyacın var
  1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: adım 1, 3 resimden 1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: adım 1, 3 resimden 2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: adım 1, 3 resimden 3.
    • Take the Philips screwdriver and remove two Philips head screws on both sides of the high mount brake lamp.
    • Be sure to store the two Philips screws in a safe place so they don't get lost.
  2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: adım 2, 2 resimden 1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: adım 2, 2 resimden 2.
    • Pull out the truck high mount brake/tail light housing.
    • We recommend you pull out the housing with both hands so you don't break the water tight seal.
    • If in the event that you happen you break it, you may have some water leak issues so you would have to fix the high mount brake/tail lamp housing with some glue.
  3. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: adım 3, 3 resimden 1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: adım 3, 3 resimden 2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: adım 3, 3 resimden 3.
    • Remove the stock bulbs from its socket.
  4. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: adım 4, 1 resimden 1.
    • Replace with the LED bulb.
    • Test your new LED truck high mount brake lamps to make sure everything works.
    • If the LED lights don't light up, check the polarity by flipping the bulbs 180 degrees.
  5. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: adım 5, 3 resimden 1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: adım 5, 3 resimden 2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: adım 5, 3 resimden 3.
    • Put back the light housing and screw in the two Philips screws.
Sonuç
Test and enjoy your new LED truck high mount brake/tail replacement lights.
2 farklı kişi bu kılavuzu tamamladı.
Eric Wu
3.357 İtibar
23 adet Kılavuz yazıldı
2 Yorum
The problem is there are no screws to remove.
richard - Yanıt
there are no screws to remove on my 3rd light I can’t change the bulb
richard - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 30
Her zaman: 5,982
