Ana içeriğe geç
1999-2004 Honda Odyssey Trunk Struts Replacement
Neye ihtiyacın var
  1. 1999-2004 Honda Odyssey Trunk Struts Replacement, Trunk Struts: adım 1, 1 resimden 1.
    • IMPORTANT: Make sure to securely prop open the trunk with something sturdy. (if not have someone hold open the trunk)
  2. 1999-2004 Honda Odyssey Trunk Struts Replacement: adım 2, 1 resimden 1.
    • Use a small flat head screwdriver to pry open the clip. Insert the screwdriver head into the smal opening. (this picture shows the clip closed)
  3. 1999-2004 Honda Odyssey Trunk Struts Replacement: adım 3, 1 resimden 1.
    • Once the clip is open, simply pull the strut away from trunk. It might require a little force, but should easily come off. You may have to lift the trunk a little.
  4. 1999-2004 Honda Odyssey Trunk Struts Replacement: adım 4, 1 resimden 1.
    • Repeat for the bottom strut. Open clip and remove strut.
    • Adding the new strut is easy. The strut should just snaps into place. You should hear a click when its on properly. Make sure to wiggle it a little to make sure its on.
    • You may have to lift the trunk to get the strut to fit at both ends.
    • Repeat on other side. I would recommend replacing the struts as a pair.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
pacopike1
155 İtibar
1 Kılavuz yazıldı
Bir Yorum
The replacement tailgate struts from Honda come with a dab of grease in the socket at each end of the strut. Check aftermarket struts for grease and add some yourself if there’s none.
Also, while the old strut is removed, check that the mounting ball bolts are tight. Two of mine were loose.
DaveT - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 3,036
