Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The 1999-2004 Jeep Grand Cherokee has a common failure where the blower fan wire adapter overheats and melts. Use this guide to fix and repair this connector and get your AC and Heater working again!
  1. Place the car in park, activate the parking brake, and leave the car running. The blower motor is located under the dash on the passenger side of the vehicle. Push the seat back, and place your tools on the floor of the car. The blower motor is located under the dash on the passenger side of the vehicle. Push the seat back, and place your tools on the floor of the car.
    • Place the car in park, activate the parking brake, and leave the car running.
    • The blower motor is located under the dash on the passenger side of the vehicle. Push the seat back, and place your tools on the floor of the car.
  2. There are a few wires hanging below the passenger side dash. The blower motor adapter is a bundle of three wires located on the left side.
    • There are a few wires hanging below the passenger side dash.
    • The blower motor adapter is a bundle of three wires located on the left side.
    • While the car is on push and pull gently on the wire connection.
    • If the fan turns on you have identified the problem and we will fix it.
    • If the fan does not turn on the damage may not be fixable without purchasing new parts.
    • Do not grasp any wires you can not see. Do not grasp any wires that are not covered in insulation and or electrical tape.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Turn off the car. There are two screws holding the adapter in place. Using a philips screw driver, remove both screws and the adapter will come down. The two screws are identical. Be careful not to lose them.
    • Turn off the car.
    • There are two screws holding the adapter in place. Using a philips screw driver, remove both screws and the adapter will come down.
    • The two screws are identical. Be careful not to lose them.
    • Be sure the car is completely off before unscrewing anything.
  5. The connection between the three wires and the adapter box is the location of  where the fault typically occurs. Observe the damage and decide if electrical tape will be enough to hold the wires in place.
    • The connection between the three wires and the adapter box is the location of where the fault typically occurs.
    • Observe the damage and decide if electrical tape will be enough to hold the wires in place.
    • Replacement parts are available for purchase if the damage is beyond repair.
  6. Using electrical tape wrap the wires tightly until there are securely in place.
    • Using electrical tape wrap the wires tightly until there are securely in place.
  7. Screw the adapter back into place. Turn on the car and test the AC/Heater Turn on the car and test the AC/Heater
    • Screw the adapter back into place.
    • Turn on the car and test the AC/Heater
Sonuç
Enjoy your working AC and Heater!
6 farklı kişi bu kılavuzu tamamladı.
William Schaller
347 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 24-1, Green Winter 2015 Cal Poly, Team 24-1, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G1
4 Üyeler
3 adet Kılavuz yazıldı
6 Yorum
radical, thank you for this!
cgerdes714 - Yanıt
Very good job - thanks for the info
I own one WJ 4.0 m1999
The ac doesn’t turn on(no lights)
Is this loose wire connection responsible for this?
ANGELO - Yanıt
good job thanks
rad8253 - Yanıt
Share your experience in Chili's Guest Experience Survey at www.chilis-survey.com to win $ 1000 cash prize every month.
https://surveydetails.com/go-chilis-surv...
hunter - Yanıt
Thank you this solved it for me easy simple.thank you
Jessica v - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 100
Son 30 gün: 357
Her zaman: 25,043
