Ana içeriğe geç
1999-2004 Jeep Grand Cherokee Air Filter Replacement
Neye ihtiyacın var
  1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement, Engine Compartment Air Filter: adım 1, 1 resimden 1.
    • Before you start, make sure the car is off and the parking break is on.
  2. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 2, 2 resimden 1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 2, 2 resimden 2.
    • Pull out the hood release handle, which will pop up the hood of the car.
    • The release is located by the driver's seat to the left of the peddles.
  3. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 3, 2 resimden 1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 3, 2 resimden 2.
    • Unlatch the hood of the car.
    • Stick your fingers in the gap between the hood and the grill, and feel for a little latch.
    • Press on the latch while also pushing the hood of the car up.
    • Once the hood is unlatched, push it all the way up. It's held there by struts so don't worry about finding the hood prop.
  4. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 4, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 4, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 4, 3 resimden 3.
    • The air filter housing is on the right front corner of the engine compartment.
    • Unlatch all four of the clips , which are located at the corners of the air filter housing and hold the housing together.
  5. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 5, 2 resimden 1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 5, 2 resimden 2.
    • Gently lift the top half of the housing, and hold it off to the side with one hand.
    • Don't pull the housing too far to the side because it is still attached to the rest of the engine.
    • You can use a flathead screw driver to help pry up the top of the casing.
  6. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 6, 2 resimden 1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 6, 2 resimden 2.
    • Remove the old air filter and clean any debris out of the bottom half of the housing.
  7. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 7, 2 resimden 1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 7, 2 resimden 2.
    • Place the new filter in the bottom half of the housing.
    • Make sure the air filter is positioned correctly with the mesh side facing up.
  8. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 8, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 8, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: adım 8, 3 resimden 3.
    • Place the top half of the housing back on the bottom half. Make sure the top fits tight back in place.
    • Reattach all four clips on the outside of the casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 91
Her zaman: 2,653
