Ana içeriğe geç
1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement
Neye ihtiyacın var
  1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: adım 1, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: adım 1, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: adım 1, 3 resimden 3.
    • Here is the Jeep GC. Removal of the headlamp is identical for both sides.
    • By opening the hood and looking straight down on the headlamp assembly, the 6mm hex head jack screw can be seen.
    • Use a 6mm socket and nut driver to remove the jack screw. 1/4 socket will not fit 9/32 does, but it is a bit sloppy
  2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: adım 2, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: adım 2, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: adım 2, 3 resimden 3.
    • Remove the long jack screw.
    • Grasp upper inboard and lower outboard corners of headlamp and forcefully pull headlamp outward.
    • Remove all bulb sockets from headlamp module. Separate headlamp from vehicle.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
oldturkey03
782.480 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
33 Üyeler
544 adet Kılavuz yazıldı
4 Yorum
It’s a 7mm socket
Don Marcos - Yanıt
Not on mine. Just rechecked and it is a 6mm on my Jeep
oldturkey03 -
Thankful for simple instructions without any extra info or words ?
robinrogersk9 - Yanıt
I’m removing it to replace fan cooling module. I heard I can cut through to get to it without disassembling the grill bumper etc
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 34
Her zaman: 7,561
