Ana içeriğe geç
1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement
Neye ihtiyacın var
  1. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement, Power Steering Pressure Hose: adım 1, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement, Power Steering Pressure Hose: adım 1, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement, Power Steering Pressure Hose: adım 1, 3 resimden 3.
    • Here is a view of the power steering pump. It is located on the front left side in the engine compartment. Visible fresh oil stains on the fan shroud and other parts.
    • Most sludge was found at the pressure line connection
    • The leak is on top of the flare nut where the pipe enters the pump.
  2. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 2, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 2, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 2, 3 resimden 3.
    • To remove the hoses from the power steering pump, the air cleaner housing has to be removed. Remove the four clips on the air filter cover
    • Remove the air filter
    • Loosen the clamps from the air intake duct to remove the air cleaner cover from the engine.
  3. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 3, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 3, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 3, 3 resimden 3.
    • Here is the complete housing. There are three 13mm hex head mounting bolts for the air cleaner housing. One on the front left
    • one on the rear left
    • and the last one is difficult to find on the front right.
  4. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 4, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 4, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 4, 3 resimden 3.
    • All three bolts have lock nuts that can be accessed from the driver side front wheel well
    • Use a socket wrench or similar tool to loosen the bolts, then remove the nuts in the wheel well.
    • All three bolts and nuts are identical
  5. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 5, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 5, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 5, 3 resimden 3.
    • With the three bolts remove the air filter housing can simply removed. This gives full access to the power steering gear and hoses.
    • New line.
    • Use a 16mm x 18mm flare nut wrench. It will be safer than an open end wrench since it provides a better grip. This will prevent any damage to the flare nut on the hose.
    • Disconnect the hose on the power steering pump by loosing the flare nut in a counter clockwise rotation
  6. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 6, 3 resimden 1. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 6, 3 resimden 2. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 6, 3 resimden 3.
    • Disconnect the hose on the power steering gear by loosing the flare nut in a counter clockwise rotation
    • Once both ends are disconnected, remove the hose from the vehicle.
    • New line.
    • Install the supplied O-rings on either side of the new hose.
  7. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: adım 7, 1 resimden 1.
    • Install new power steering pressure hose.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
oldturkey03
782.246 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
33 Üyeler
537 adet Kılavuz yazıldı
9 Yorum
This was so helpful! I have this exact issue with my power steering and this guide is going to make the job very easy! Thanks for posting this it really helped a lot!
Hadley Hofreiter - Yanıt
Doing this job today thanks for making this! I didn't know I would need a flare nut wrench and luckily found one pretty cheap
Albert Einstein - Yanıt
After topping up the steering fluid, the system can be bled again by turning the wheels from left lock to right lock a few times. Much easier when both wheels are off the ground.
Andries Holtzhausen - Yanıt
Does the fluid not need to be drained out before removing the line?
Dave - Yanıt
@dave7777 nope. Place a rag under the hose before you take it off so it does not leave to much of a mess. Check the fluid after.
oldturkey03 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 37
Son 30 gün: 158
Her zaman: 42,800
