Ana içeriğe geç
1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement
Neye ihtiyacın var
  1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Plastic Rain Tray: adım 1, 1 resimden 1.
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 2, 1 resimden 1.
    • Remove the rubber gasket from the rain tray.
  3. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 3, 1 resimden 1.
    • Lift the tray upwards and away from the vehicle.
  4. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Front Windshield Wipers: adım 4, 1 resimden 1.
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 5, 1 resimden 1.
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  6. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 6, 2 resimden 1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 6, 2 resimden 2.
    • Gently lift up the passenger-side windshield wiper.
  7. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 7, 1 resimden 1.
    • Remove the driver-side windshield wiper in the same fashion.
  8. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: adım 8, 2 resimden 1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: adım 8, 2 resimden 2.
    • Lift up the plastic cover.
  9. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 9, 2 resimden 1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 9, 2 resimden 2.
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  10. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 10, 1 resimden 1.
    • Use a #2 Phillips screwdriver to remove the front two screws.
  11. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 11, 2 resimden 1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: adım 11, 2 resimden 2.
    • Gently unplug and lift out the automatic transmission control unit.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Matthew Newsom
39.496 İtibar
67 adet Kılavuz yazıldı
5 Yorum
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - Yanıt
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - Yanıt
got a question if your display light is dim what could be the problem
dean wafula - Yanıt
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - Yanıt
thank you very much .
emad_szs - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 132
Her zaman: 43,661
