Ana içeriğe geç
1999 - 2003 Acura TL Ignition Coil Replacement
Neye ihtiyacın var
  1. 1999 - 2003 Acura TL Ignition Coil Replacement, Ignition Coil: adım 1, 2 resimden 1. 1999 - 2003 Acura TL Ignition Coil Replacement, Ignition Coil: adım 1, 2 resimden 2.
    • Open the driver side door of car.
  2. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 2, 2 resimden 1. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 2, 2 resimden 2.
    • Pull the hood latch below the steering wheel and near the door frame towards you to pop open the hood.
  3. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 3, 2 resimden 1. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 3, 2 resimden 2.
    • Lift the hood slightly to where your fingers can fit under the hood.
    • Reach your fingers under the hood to find the latch that is slightly right off the center.
    • Pull and hold the latch up while simultaneously lifting the hood all the way up until it stays stationary.
    • Be careful that the hood is lifted properly to avoid an accident.
  4. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 4, 3 resimden 1. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 4, 3 resimden 2. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 4, 3 resimden 3.
    • Use a flathead screwdriver to remove one screw from each corner of the cover.
  5. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 5, 1 resimden 1.
    • Pull the engine cover towards you to remove it.
  6. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 6, 3 resimden 1. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 6, 3 resimden 2. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 6, 3 resimden 3.
    • Pinch the socket, attached to engine coil, and pull up to release.
    • With an Allen key, loosen the screw holding the coil by turning counterclockwise.
    • Make sure to avoid exposed wires.
  7. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 7, 3 resimden 1. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 7, 3 resimden 2. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 7, 3 resimden 3.
    • Pull out the old coil.
    • Avoid exposed wires.
  8. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 8, 3 resimden 1. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 8, 3 resimden 2. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 8, 3 resimden 3.
    • Insert the new coil.
  9. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 9, 2 resimden 1. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 9, 2 resimden 2.
    • Attach the wire socket to the new coil until you hear a "click," indicating that it is properly inserted.
  10. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 10, 1 resimden 1.
    • With an Allen key, tighten the screw into the new coil turning clockwise to secure into place.
  11. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 11, 3 resimden 1. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 11, 3 resimden 2. 1999 - 2003 Acura TL Ignition Coil Replacement: adım 11, 3 resimden 3.
    • Reattach the engine cover and secure the screws with the flathead screwdriver.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 150
