Giriş
This is a step-by-step guide will show you how to replace the ignition coil of your 1999 - 2003 Acura TL. Though this is a guide to replace a single coil, it is highly recommended that all of the ignition coils are replaced once or the engine may start to misfire. By following this guide you can save yourself an expensive trip to the mechanic.
Before you begin, turn off the car and put it in park. If you have driven recently, wait for the engine to cool before starting the repair.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
