Giriş
If you find that your steering wheel is whining when turning, or it is hard to turn while parked, it may be because your Hydroboost is worn. About 100-200$ online, or cheaper at a pick-a-part yard, this is a simple fix. Allow 1-4 hours depending on skill and tools. Usually the problem is an O ring, which is a 12$ part, but it is quite tedious to fix in the first place.
Neye ihtiyacın var
Open the hood, locate the brake fluid reservoir. Right under that is the Hydroboost device.
One of the critical things is to make sure the linkage to the brake pedal to the Hydroboost and the sensor are lined up correctly.
