Ana içeriğe geç
2001-2007 Toyota Highlander Engine Air Filter Replacement
Neye ihtiyacın var
  1. 2001-2007 Toyota Highlander Engine Air Filter Replacement, Engine Air Filter: adım 1, 1 resimden 1.
    • Pop the hood open using the latch beneath the driver side dash near the pedals.
  2. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 2, 3 resimden 1. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 2, 3 resimden 2. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 2, 3 resimden 3.
    • Open the hood using the latch beneath the hood.
    • After popping it open, prop it up with the hood stick.
  3. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 3, 1 resimden 1.
    • Locate the air filter box in the driver side of the engine bay behind the battery.
  4. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 4, 3 resimden 1. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 4, 3 resimden 2. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 4, 3 resimden 3.
    • Unclip the single clip on the box by pulling up on it.
    • Lift the cover up to remove it from the filter.
  5. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 5, 3 resimden 1. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 5, 3 resimden 2. 2001-2007 Toyota Highlander Engine Air Filter Replacement: adım 5, 3 resimden 3.
    • Lift the air filter up to remove it from the car and replace it with a new one.
Sonuç
Omar Ajjaoui
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 1,067
