Ana içeriğe geç
2001-2006 Mini Cooper Cabin Air Filter Replacement
  1. 2001-2006 Mini Cooper Cabin Air Filter Replacement, Cabin Air Filter: adım 1, 3 resimden 1. 2001-2006 Mini Cooper Cabin Air Filter Replacement, Cabin Air Filter: adım 1, 3 resimden 2. 2001-2006 Mini Cooper Cabin Air Filter Replacement, Cabin Air Filter: adım 1, 3 resimden 3.
    • Locate the air filter housing unit below the glove box.
    • Open housing unit to reach air filter by locating the three clips, one on the rear of the box and the two on the front.
    • Open the rear clip first by applying an outward and downward force. Repeat process for the front clips.
  2. 2001-2006 Mini Cooper Cabin Air Filter Replacement: adım 2, 2 resimden 1. 2001-2006 Mini Cooper Cabin Air Filter Replacement: adım 2, 2 resimden 2.
    • Filter lays in a pair of guide rails for easy removal and replacement.
    • Pinch base of filter with thumb.
    • Once the filter is pinched it can easily be pulled out by the guide rails with moderate force.
  3. 2001-2006 Mini Cooper Cabin Air Filter Replacement: adım 3, 1 resimden 1.
    • Replace the old filter with the new filter.
    • Reassemble the air filter by following the guide in reverse. On the side of the filter, there should be writing telling which direction the air flow goes in for putting it back in right way up. The air should be flowing into the foot well so you want the arrows pointing down.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Eli
363 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 8-19, Regan Fall 2013 Cal Poly, Team 8-19, Regan Fall 2013 üyesi
CPSU-REGAN-F13S8G19
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
thank you for your page…you made it easy to understand…and the pics were great also!
Debbie Ross - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 74
Her zaman: 7,985
