Ana içeriğe geç
2001-2006 Mini Cooper Radio Replacement
Neye ihtiyacın var
  1. 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: adım 1, 3 resimden 1. 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: adım 1, 3 resimden 2. 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: adım 1, 3 resimden 3.
    • Grab the knee bolster panel under the steering column with both hands.
    • Pull it down and out.
    • Using a Torx screwdriver with T30 tip, remove the two M5 x 2.5 x 25 screws in the left pillar.
  2. 2001-2006 Mini Cooper Radio Replacement: adım 2, 3 resimden 1. 2001-2006 Mini Cooper Radio Replacement: adım 2, 3 resimden 2. 2001-2006 Mini Cooper Radio Replacement: adım 2, 3 resimden 3.
    • Open the glovebox.
    • Using a Torx screwdriver with a T20 tip, remove the two M5 x 2.5 x 30 screws in the right hand side pillar.
    • Minis in America will usually have a cup holder attached with these 2 screws on the right. It will come off when the 2 screws are removed and can be set to the side.
  3. 2001-2006 Mini Cooper Radio Replacement: adım 3, 3 resimden 1. 2001-2006 Mini Cooper Radio Replacement: adım 3, 3 resimden 2. 2001-2006 Mini Cooper Radio Replacement: adım 3, 3 resimden 3.
    • With the glovebox still open, grab the bottom of the passenger dash panel and pull it forward. The panel does not need to be removed, just popped out.
    • Grab under the driver side dash panel near the radio and pull it forward. Again, the panel does not need to be removed, just popped out.
    • Pull each side of the middle dash panel until it pops out, like the previous ones.
  4. 2001-2006 Mini Cooper Radio Replacement: adım 4, 3 resimden 1. 2001-2006 Mini Cooper Radio Replacement: adım 4, 3 resimden 2. 2001-2006 Mini Cooper Radio Replacement: adım 4, 3 resimden 3.
    • Grab the left hand side pillar, then pull it out and to the left.
    • Grab the right hand side pillar, then pull it out and to the right.
    • The four screws holding the radio in should now be exposed.
  5. 2001-2006 Mini Cooper Radio Replacement: adım 5, 3 resimden 1. 2001-2006 Mini Cooper Radio Replacement: adım 5, 3 resimden 2. 2001-2006 Mini Cooper Radio Replacement: adım 5, 3 resimden 3.
    • Using a screwdriver with a T20 bit, take out the four M3 x 2 x 20 screws holding the radio in place.
    • Some models have philips head screws instead of the regular torx head depending on age.
  6. 2001-2006 Mini Cooper Radio Replacement: adım 6, 2 resimden 1. 2001-2006 Mini Cooper Radio Replacement: adım 6, 2 resimden 2.
    • Grab the radio and gently pull it out of the dash.
  7. 2001-2006 Mini Cooper Radio Replacement: adım 7, 3 resimden 1. 2001-2006 Mini Cooper Radio Replacement: adım 7, 3 resimden 2. 2001-2006 Mini Cooper Radio Replacement: adım 7, 3 resimden 3.
    • Pinch the antenna connector and pull it straight out.
  8. 2001-2006 Mini Cooper Radio Replacement: adım 8, 2 resimden 1. 2001-2006 Mini Cooper Radio Replacement: adım 8, 2 resimden 2.
    • For the main connector, pinch the lever arm with the piece of plastic next to it.
    • Lift up on the arm and pull the connector out.
    • The radio can now be removed from the car.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
I bought everything to install a aftermarket radio in my 2005. Mini s. Everything lights up. Stations tune in but no sound
Roy Ober - Yanıt
The replacement radio powers on but there's no audio. Which wire provides power to the amp for audio? It seems like I've tried them all....
Olu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 55
Son 30 gün: 318
Her zaman: 14,568
