Giriş
If the radio in your first generation Mini Cooper (R50/52/53) has stopped working or you want to put in an aftermarket radio, this guide will show you how to remove the factory radio. There are no special skills required to do so. Some of the plastic dash panels may be older and more brittle, so be careful when pulling them. NOTE: If you’re putting in an aftermarket radio and want to retain the steering wheel controls, you need to make sure you buy an adapter kit.
Neye ihtiyacın var
Grab the knee bolster panel under the steering column with both hands.
Pull it down and out.
Using a Torx screwdriver with T30 tip, remove the two M5 x 2.5 x 25 screws in the left pillar.
With the glovebox still open, grab the bottom of the passenger dash panel and pull it forward. The panel does not need to be removed, just popped out.
Grab under the driver side dash panel near the radio and pull it forward. Again, the panel does not need to be removed, just popped out.
Pull each side of the middle dash panel until it pops out, like the previous ones.
5 farklı kişi bu kılavuzu tamamladı.
