Ana içeriğe geç
2001-2005 Honda Civic Oil level Check and oil change
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. 2001-2005 Honda Civic Oil level Check and  oil change, 2001-2005 Honda Civic Oil level Check and  oil change: adım 1, 1 resimden 1.
    • Warning: Improper maintenance or use of unapproved materials may lead to major issues with your automobile
    • Step 1: Turn off your vehicle and wait a few minutes.
    • Starting this process with a running or hot car may cause damage to both the engine as well as the person performing the maintenance
  2. 2001-2005 Honda Civic Oil level Check and  oil change: adım 2, 1 resimden 1.
    • Remove the dipstick from its' holder and wipe it down with a clean cloth
    • After cleaning, replace the dipstick and remove it again
  3. 2001-2005 Honda Civic Oil level Check and  oil change: adım 3, 1 resimden 1.
    • If an oil change is not necessary, the oil will be a dark brown, and the level will be in between the two notches on the dipstick.
    • If the level is too high or low, it's time to add/change the oil
  4. 2001-2005 Honda Civic Oil level Check and  oil change: adım 4, 1 resimden 1.
    • Step 1: After running the car to normal operating temperature, turn off the vehicle and remove the black and purple oil fill cap.
    • Underneath the car, use your ratchet socket wrench to remove the oil drain bolt and washer.
    • Remove the oil filter from the tank and allow all of the oil to drain out.
  5. 2001-2005 Honda Civic Oil level Check and  oil change: adım 5, 1 resimden 1.
    • After all of the oil is drained out, replace all parts in reverse order that they were removed.
    • If the oil filter appears old or damaged, it is wise to replace it. Oil filters can be found at any auto parts store
    • Add 5W-20 Motor oil to the level indicated in your owners manual.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tyler Smith
846 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 üyesi
UMASSD-VIJAYBHASKAR-F13S4G5
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Where is the oil filter located? An important step was left out!!
Gil - Yanıt
This guide has been retired and is no longer being updated. Please use the latest version of the 2001-2005 Civic oil change guide. Thanks!
Jeff Suovanen -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 4,395
