Ana içeriğe geç
2001 Chevrolet Suburban Rear Window Struts Replacement
Neye ihtiyacın var
  1. 2001 Chevrolet Suburban Rear Window Struts Replacement, Rear Window Struts: adım 1, 2 resimden 1. 2001 Chevrolet Suburban Rear Window Struts Replacement, Rear Window Struts: adım 1, 2 resimden 2.
    • Open the window.
    • Support the window with either a partner's hands or a sturdy prop.
    • A prop is used in the photos.
  2. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 2, 2 resimden 1. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 2, 2 resimden 2.
    • Position the small screwdriver on the indentation in the lower joint of the strut.
    • Gently wedge the screwdriver under the metal locking tab and pop it out.
    • You don't have to completely remove the tab—just make sure it doesn't pop back into place. Getting a screwdriver completely under it (as shown) is usually enough.
    • If needed, use the larger screwdriver to help loosen the tab.
  3. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 3, 2 resimden 1. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 3, 2 resimden 2.
    • Position the screwdriver on the indentation in the upper joint.
  4. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 4, 2 resimden 1. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 4, 2 resimden 2.
    • Stand at the back of the vehicle (behind the rear bumper) and face the lower joint of the strut.
    • Grab the lower joint.
    • Pull firmly, straight towards you and slightly upwards until the joint pops off.
  5. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 5, 2 resimden 1. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 5, 2 resimden 2.
    • Stand at the side of the vehicle and face the upper joint of the strut.
    • Grab the upper joint.
    • Pull firmly, straight towards you until the joint pops off. Do not pull upwards or downwards.
  6. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 6, 2 resimden 1. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 6, 2 resimden 2.
    • Remove the new strut from its packaging.
    • Align the socket of the upper joint with the mounting stud.
    • The upper joint is on the end with the thick black plastic.
    • Firmly press the joint until it snaps on.
  7. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 7, 2 resimden 1. 2001 Chevrolet Suburban Rear Window Struts Replacement: adım 7, 2 resimden 2.
    • Align the socket of the bottom joint with the mounting stud.
    • The bottom joint is on the end with the bare metal rod.
Sonuç
Repeat this process for the other strut. That’s it!
Alex Dierks
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 581
