Ana içeriğe geç
2002-2008 Dodge Ram 1500 Coolant replacement
Neye ihtiyacın var
  1. 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: adım 1, 3 resimden 1. 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: adım 1, 3 resimden 2. 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: adım 1, 3 resimden 3.
    • Locate the coolant reservoir, near the front of the engine bay.
    • Do not remove the reservoir cap if the engine has overheated. Doing so may result in a steam explosion as pressure is released.
    • Locate the coolant reservoir cap and remove it by pressing down and turning it counterclockwise.
    • Never fill up the coolant while the engine is hot. This may cause the engine block to crack.
    • If the coolant level is low, fill up the reservoir using a 50/50 mixture of antifreeze and distilled water.
    • Many types of antifreeze coolant are pre-mixed, so read the instructions on the bottle before diluting with water.
  2. 2002-2008 Dodge Ram 1500 Coolant replacement: adım 2, 3 resimden 1. 2002-2008 Dodge Ram 1500 Coolant replacement: adım 2, 3 resimden 2. 2002-2008 Dodge Ram 1500 Coolant replacement: adım 2, 3 resimden 3.
    • If you need to completely drain the coolant, place a bucket underneath the coolant hose, near the front of the engine.
    • Locate and loosen the hose clamp on the coolant hose with the flat head screwdriver. The coolant hose is located near the bottom of the serpentine belt underneath the front of the engine bay.
    • Drain the coolant completely and reattach the coolant hose, tightening the hose clamp with the flat head screwdriver.
    • Dispose of your used coolant at an auto parts shop or a landfill that accepts hazardous materials. Do not pour it down a storm drain or sink.
    • Remember to refill the reservoir tank with coolant before driving your Dodge truck. Driving without coolant will cause overheating and engine damage.
    • Due to limited resources the coolant was not actually drained in this guide.
Sonuç
To dispose of your used coolant, take it to an automotive parts store or to any landfill that accepts hazardous materials. Do not pour coolant down any drains or sinks. Serious ecological damage could occur.
4 farklı kişi bu kılavuzu tamamladı.
Michael Saggese
1.021 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G24
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Thanks a million very helpful advice !
kenneth.williamsbam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 136
Her zaman: 55,172
