Ana içeriğe geç
2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement
Neye ihtiyacın var
  1. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Headlight Assembly: adım 1, 3 resimden 1. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Headlight Assembly: adım 1, 3 resimden 2. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Headlight Assembly: adım 1, 3 resimden 3.
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: adım 2, 1 resimden 1.
    • In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
  3. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: adım 3, 3 resimden 1. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: adım 3, 3 resimden 2. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: adım 3, 3 resimden 3.
    • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
    • Unscrew the second screw located approximately 6 inches below the first.
    • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
    • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
  4. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: adım 4, 2 resimden 1. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: adım 4, 2 resimden 2.
    • Approach this step with the process of unbuttoning a shirt in mind.
    • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
    • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
  5. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: adım 5, 2 resimden 1. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement: adım 5, 2 resimden 2.
    • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
    • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
    • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
  6. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Front Turn Signal Bulb: adım 6, 3 resimden 1. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Front Turn Signal Bulb: adım 6, 3 resimden 2. 2002-2008 Dodge Ram 1500 Front Turn Signal Bulb Replacement, Front Turn Signal Bulb: adım 6, 3 resimden 3.
    • Turn the turn signal bulb holder counterclockwise until it stops.
    • Remove the bulb holder.
    • Inspect the bulb. Check for broken filaments or cracked glass.
    • Be sure to replace the turn signal bulb with the correct type for your Dodge. Using an incorrect bulb will result in shortened bulb or fuse lifespan.
Sonuç
To reassemble the headlight assembly, follow these instructions in reverse order.
6 farklı kişi bu kılavuzu tamamladı.
Michael Saggese
1.021 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G24
4 Üyeler
11 adet Kılavuz yazıldı
4 Yorum
WRONG! Just reach around behind and pop the bulb out. This is A LOT of unnecessary steps for absolutely NO REASON.
Kimberly Parrish-Sanders - Yanıt
haha…try that on my 2007! Drivers side is impossible to reach. gotta take the whole light fixture.
Randy Drues -
How do you change left side FRONT turn signal bulb on a 2011 CHRYSLER 200
alan burton - Yanıt
no way you can change my CHRYSLER 2011 200 model this way
alan burton - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 39
Son 30 gün: 145
Her zaman: 50,048
