Ana içeriğe geç
2002-2006 Acura Integra Hatch Strut Replacement
Neye ihtiyacın var
  1. 2002-2006 Acura Integra Hatch Strut Replacement, Hatch Strut: adım 1, 1 resimden 1.
  2. 2002-2006 Acura Integra Hatch Strut Replacement: adım 2, 3 resimden 1. 2002-2006 Acura Integra Hatch Strut Replacement: adım 2, 3 resimden 2. 2002-2006 Acura Integra Hatch Strut Replacement: adım 2, 3 resimden 3.
    • Go to the rear of the vehicle.
    • Pull up on the trunk handle to lift open the trunk.
  3. 2002-2006 Acura Integra Hatch Strut Replacement: adım 3, 3 resimden 1. 2002-2006 Acura Integra Hatch Strut Replacement: adım 3, 3 resimden 2. 2002-2006 Acura Integra Hatch Strut Replacement: adım 3, 3 resimden 3.
    • Prop open hatch or have someone help support the hatch weight.
    • Remove the upper ball mount.
    • Turn the upper ball mount counterclockwise with a 12mm wrench.
    • It will pop off when it's completely unscrewed.
  4. 2002-2006 Acura Integra Hatch Strut Replacement: adım 4, 2 resimden 1. 2002-2006 Acura Integra Hatch Strut Replacement: adım 4, 2 resimden 2.
    • Remove the lower ball mount.
    • Turn the lower ball mount counterclockwise with a 12mm wrench.
  5. 2002-2006 Acura Integra Hatch Strut Replacement: adım 5, 3 resimden 1. 2002-2006 Acura Integra Hatch Strut Replacement: adım 5, 3 resimden 2. 2002-2006 Acura Integra Hatch Strut Replacement: adım 5, 3 resimden 3.
    • Place a washer on the new upper ball mount.
    • Turn it clockwise to hand tighten the new upper ball mount.
    • Turn it clockwise with the crescent wrench to finish tightening.
  6. 2002-2006 Acura Integra Hatch Strut Replacement: adım 6, 2 resimden 1. 2002-2006 Acura Integra Hatch Strut Replacement: adım 6, 2 resimden 2.
    • Place a washer on the new lower ball mount.
    • Turn it clockwise to hand tighten the new lower ball mount.
    • Turn it clockwise with a crescent wrench to finish tightening the new lower ball mount.
  7. 2002-2006 Acura Integra Hatch Strut Replacement: adım 7, 2 resimden 1. 2002-2006 Acura Integra Hatch Strut Replacement: adım 7, 2 resimden 2.
    • Place a lower hatch strut socket over the new lower ball mount.
    • Push it firmly onto the new lower ball mount. It will pop on easily.
  8. 2002-2006 Acura Integra Hatch Strut Replacement: adım 8, 1 resimden 1.
    • Place the upper hatch strut socket over the new upper ball mount.
    • Press it firmly onto the new upper ball mount. It will pop on easily.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 710
