Ana içeriğe geç
2002-2006 Toyota Camry Key Fob Battery Replacement
Neye ihtiyacın var
  1. 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: adım 1, 2 resimden 1. 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: adım 1, 2 resimden 2.
    • Purchase a new lithium coin battery. You can find it at your local hardware store.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  2. 2002-2006 Toyota Camry Key Fob Battery Replacement: adım 2, 1 resimden 1.
    • Use your hands or a spudger to separate the key fob into two pieces.
  3. 2002-2006 Toyota Camry Key Fob Battery Replacement: adım 3, 1 resimden 1.
    • Identify which part of the FOB holds the battery.
    • You will not need the other part of the fob until the end.
  4. 2002-2006 Toyota Camry Key Fob Battery Replacement: adım 4, 2 resimden 1. 2002-2006 Toyota Camry Key Fob Battery Replacement: adım 4, 2 resimden 2.
    • Remove the battery from the fob by releasing it from the holder using a spudger or by hand.
    • Be careful that you don't break the contacts when removing the battery.
  5. 2002-2006 Toyota Camry Key Fob Battery Replacement: adım 5, 1 resimden 1.
    • Insert the new battery by pushing it down.
  6. 2002-2006 Toyota Camry Key Fob Battery Replacement: adım 6, 1 resimden 1.
    • Reassemble the fob, using your hands to press the two parts together.
Sonuç
Salman Abu Mazen
140 İtibar
1 Kılavuz yazıldı
Ekip
UM-Willis-F21S51G7 UM-Willis-F21S51G7 üyesi
Community
1 Üye
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 51
Son 30 gün: 229
Her zaman: 4,942
